Notices
Sponsored by: DashLynx
Old August 10th, 2015, 3:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Steering & Suspension Guides
Print Wikipost
2002 Electronic Ride Control
Old February 22nd, 2008, 1:37 PM
  #11
2000 zx3's Avatar
Default RE: 2002 Electronic Ride Control
Old February 22nd, 2008, 6:54 PM
  #12
ehhget's Avatar
My truck does not have that option but I have always understood it to simply adjust ride firmness not height so when you asked why is the front of your truck lower than the back that is because that is the normal slope of a chevy truck unless you add a leveling kit or a lift.
Old February 22nd, 2008, 10:11 PM
  #13
2000 zx3's Avatar
it DOES not adjust the height of the truck , just like the corvette ride control it firms up the shocks . anymore questions ???
Old February 25th, 2008, 1:26 PM
  #14
ehhget's Avatar
What? I think you capitalized the wrong word to make your point but I think you were agreeing with me, right??
Old January 26th, 2009, 9:33 AM
  #15
TerWarren's Avatar
Exclamation 2000 zx3 help!
My two-position switch went out over the weekend as well. I believe I also need new shocks. Can anyone here give me the part numbers and prices for these electronic shocks? I also need the part number and price for a new switch… or can it be fixed by taking it apart? Please help I have been searching for a very long time. I found this…
www.gmfullsize.com
Re: GM Part Number Thread
Quote: Originally Posted by Denaliano
Lets see how good ya are
RPO ZX3 Electronic Ride Control Shocks my truck
PN#s and Price plz
Best I could do without a VIN is:
22400192 - front (Delco # 580-226)
22400246 - rear (Delco # 580-235)
both are code ZX3, and of course, the rears are code NYS
Can anyone confirm? (Mine are made by Delphi) Does anyone make an after market replacement part that will work with this system? Please e-mail me and post to this thread so everyone else will know. Thanks to all in advance.
Old January 29th, 2009, 10:11 AM
  #16
TerWarren's Avatar
Anyone???
Old January 30th, 2009, 9:25 AM
  #17
TTune's Avatar
You are all quite correct as the switch (Gm #1505 2073) works the same as a toggle. In for on, & out for normal however I have the same issue & while you hold the button in it works(mine's failed), but it is a cheap switch (Z71 option). I'm on my 2nd switch in 2 months so what causes the switch to fail? If you think your lights, locks, window switches work 1000's of times with no issues, why is this so problematic. I'm thinking it's a short as the switch gets hot, then fails. Any thoughts are welcome.
Thanks...TTune..
Old May 24th, 2009, 1:37 PM
  #18
stevenheard's Avatar
Default 2002 Chevrolet Silverado Ride Control
I have a 2002 Silverado and my ride control is not working. I have checked the fuses and other things and have not found the problem. When you press the switch and hold sometimes the light comes on and sometimes it doesn't. If you wiggle the switch while holding it in the light will come on. Does anyone know if the switch is the problem and if so how do you change it?
Thanks - Steve
Old January 17th, 2010, 12:36 AM
  #19
parkrider6996's Avatar
Default Ride control Shocks
I own a 2001 Silverado 1500 4x4, that has the electronic ride control on it. The shocks are ready to be replaced, can anyone steer me to where I can get new ones. I have done tons of searches online and cann't seem to find any. Thanks alot!
Old January 26th, 2011, 11:09 AM
  #20
jduca's Avatar
Exclamation Ride Control Issue Fixed
I have a 2002 Chevy Silverado with the ride control switch. I have replaced the switch multiple times. Cost is about $60 at the dealer. I recently stopped getting new ones and fixed the switch myself. I was able to replace the push-button switch with a black rocker switch and it works fine. Looks stock and will not fail as the O&M switch did. If you are interested let me know. The fix cost about $25 and should not fail as the original one did. Send me a message if interested.
- John
Quick Reply: 2002 Electronic Ride Control
