2005 chevy transmission problem
i have a 2005 silverado crew cab z71 auto trans.
i was driving down the road about 40 mph. all of a sudden its like its in neutral. so i shift it down to 3rd and it works fine. i go about 1/4 mile and let off the gas to turn, when i give gas again, same thing.
so i shift to 2nd. 2nd works fine.
once i get started in 2nd i can shift to 3rd and it will work most of the time.
while driving i put it into 4wd high, once it engaged i shifted to drive and it started working. while in drive i go back to 2wd and it keeps working. i only did that once. i only drove about 5 miles since this has happened. i backed out of drive way, put it into 2nd, it made a few noises and then stopped. other than that there were no strange noises, just no drive or third gear unless i go through steps.
i checked transmission fluid and the level looked fine.
If anyone can shed any light on this i would really appreciate it.
Thanks
Thanks
Mike Bolerjack (December 22nd, 2020)
kelannigan
Silverado & Fullsize Pick-ups
10
January 27th, 2022 6:02 PM
rjhill0489@gmail.com
July 4th, 2014 6:46 PM
Brok
May 2nd, 2013 8:56 PM
