2005 Chevy Silverado daytime running lights
The daytime running lights on my 2005 Chevy Silverado came on while engine was off. I jumped it off and ran it to charge the battery but the lights did not go off. A month ago I changed out the headlight switch, which solved the problem for a month but to no avail. Does anyone know how to solve this problem?
If you remove the bulbs, the 'carrier' in which you insert the bulbs should still be there -- so you probably need not worry about water getting in there. Nobody will know they are missing unless they get up VERY CLOSE and look through the lenses.
I had one of mine burn out recently and am considering removing them myself.
RitualJman
Silverado & Fullsize Pick-ups
14
May 9th, 2017 2:02 PM
troutbum
May 12th, 2015 7:45 PM
