Notices
Sponsored by: DashLynx
2006 vortex max No Oil Pressure when cold
Old September 3rd, 2012, 1:46 PM
bthomasbt's Avatar
Default 2006 vortex max No Oil Pressure when cold
I have a 2006 Chevy pu 6.0 Vortex max with 150k miles.
I have no oil pressure when I first start the engine.
I know it's not the gauge or sensing unit. Engine starts to knock.
If I raise rpm's to 1000, pressure will pick up.
Once engine gets hot oil pressure is running 25 to 30 psi.
At 2500 rpm pressure goes to 45 to 50 after it is hot.
I've changed the oil and filter every 3000 miles since it was new.
PLEASE HELP!!!!!!!!
Old September 3rd, 2012, 2:31 PM
kevinkpk's Avatar
PLEASE HELP!!!!!!!!
Change the oil pump, it sounds like it is loosing its prime. My suggestion, and if you do, make sure you prime the new one.
Old September 3rd, 2012, 3:00 PM
bthomasbt's Avatar
Thanks
Was hoping for something simple.
But figured it wasn't.
Old September 3rd, 2012, 3:17 PM
kevinkpk's Avatar
Thanks
Used to be simple, drop pan, replace pump. Odd that low mileage with a gear pump would cause issues. You do regular oil change as needed? It could be the pick screen on the pump is sludged over.
Old September 3rd, 2012, 3:38 PM
shamrock246's Avatar
Is the relief valve stuck open not up on the newer motors but aren't the pumps driven off the front of the crank
Old September 3rd, 2012, 3:48 PM
bthomasbt's Avatar
I changed the oil every 3000 miles.
Someone had already said something about the check valve being stuck.
I really don't know.
Once the oil is hot there isn't any problems.
Everything seems nomal.
Old September 4th, 2012, 7:03 AM
How many miles on it?what oil have you been using?you might be able to get the relief valve without taking the pump off maybe some where around the harmonic balancer area on the pump housing
Old September 7th, 2012, 8:32 AM
Official GM Rep
bthomasbt,
Have you had any success in getting this addressed since your last post? We hope that everything's been resolved with the help of the excellent community input!
Sarah (Assisting Louis), Chevrolet Customer Service
calnastic
February 6th, 2014 7:37 PM
not_a_car_dude
September 15th, 2013 7:41 PM
camper8251
Suspension & Tire
July 12th, 2011 2:07 PM
LTD10
April 2nd, 2008 4:30 PM
FearlessPaul
March 24th, 2007 12:23 PM
Quick Reply: 2006 vortex max No Oil Pressure when cold
