2007 Silverado 4wd problem - Chevrolet Forum - Chevy Enthusiasts Forums
Go Back   > >
Log In
LinkBack Thread Tools Search this Thread
Old 12-08-2009, 11:19 PM
Default 2007 Silverado 4wd problem
I admit I am not an expert with how 4x4 systems work, that's why I'm here. I purchased a 2007 Silverado (new body style) this summer. We just got our first big snow storm tonight, and I backed out of the driveway and was stuck on the street in front of the house as cars drove by. I was able to roll down the window and crank the front wheels so I could see the tire and it didn't move even when locked in 4 high.
I assume that all tires should move at the same in that setting? The light flashes for quite a while before locking into the 4 high setting. Is that normal? Any ideas on what the problem could be?
Old 12-09-2009, 04:25 PM
I'm a newbie with 4 wheel drive, too. I haven't even used mine, yet. (got my truck in August - 1st 4x4) But, according to the manual it says to shift into 4 wheel drive high at any speed. So, would you assume you have to be moving in order to shift into 4 wheel drive? I didn't think it could be done at a stop but I'm not sure. Hopefully someone with experience (I'm sure there's plenty on this board) can chime in.
Actually, I did try the 4 wheel drive once - it was wet out and I went in a straight line just to see if it worked. I was doing about 20 mph and it shifted into 4 wheel high very quickly and smoothly.
Not sure about doing that at a stop, though. I'd like to know.
Old 12-09-2009, 08:13 PM
i've heard with the new 4x4 systems they are shift on the fly systems. you could
try it.
Old 12-10-2009, 08:25 AM
Also, were you trying to get into 4 wheel drive low or high? Low is a different procedure - this is for electronic shifting - not the manual.
Shifting Into Four-Wheel-Drive Low
When Four-Wheel-Drive Low is engaged, vehicle speed
should be kept below 45 mph. Extended high-speed
operation in Four-Wheel-Drive Low may damage
or shorten the life of the drivetrain.
To shift to the Four-Wheel-Drive Low position, the
ignition must be in ON/RUN and the vehicle must be
stopped or moving less than 3 mph (5 km/h) with
the transmission in N (Neutral). The preferred method
for shifting into Four-Wheel-Drive Low is to have
the vehicle moving 1 to 2 mph (1.6 to 3.2 km/h).
Turn the **** to the Four-Wheel-Drive Low position.
You must wait for the Four-Wheel-Drive Low indicator
light to stop flashing and remain on before shifting
the transmission into gear.
Notice: Shifting the transmission into gear before
the requested mode indicator light has stopped
flashing could damage the transfer case. To help
avoid damaging the vehicle, always wait for the mode
indicator lights to stop flashing before shifting the
Old 12-10-2009, 11:38 AM
gotstylez's Avatar
considering my truck is more then 12 years older then your idk if this would work wih yours BUT.. on mine i reverse for a few feet to let the automatic hubs lock in.. you have to do this with the manual lock out hubs too SOMETIMES. dunno if that'll help if your still stuck LOL
Thread Thread Starter Forum Replies Last Post
2007 Chevy silverado 1500 4wd problem Gary Markham Silverado & Fullsize Pick-ups 1 08-14-2011 12:29 PM
I want to change from pusbutton 4wd to manual 4wd 04Greg Silverado & Fullsize Pick-ups 2 03-02-2011 09:46 AM
1989 4wd GMC 2500 loose 4wd vpbho Silverado & Fullsize Pick-ups 1 11-01-2010 10:08 AM
1998 Tahoe LT 4WD wire harness to tranny/4wd waller2003 Tahoe & Suburban 0 10-19-2009 09:49 PM
Help, Went into 4WD because of snow and now it is STUCK in 4WD!!! DianaT General Tech 4 11-29-2007 12:12 AM
Tags
2007, 2009, 4wd, auto, automatic, blinks, case, chevy, colorado, indicator, light, low, mode, problem, shifting, silverado, transfer, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
