2007 Silverado Dash Light? - Chevrolet Forum - Chevy Enthusiasts Forums
bmedlock's Avatar
March 1st, 2012, 9:00 PM   #1
I have a 2007 Silverado Classic 1500 Crew Cab. Only the right side of the stereo lights work and the climate control lights don't work at all. Any ideas?
Official GM Rep
Global Headquarters in Detroit, MI
March 2nd, 2012, 4:07 PM   #2
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> bmedlock,
Does the radio and climate control still work? Have you checked the fuses? Bulbs?
Louis
GM Customer Service
bmedlock's Avatar
March 3rd, 2012, 5:41 AM   #3
The radio and climate control both still work. I checked the fuses and they are all good. I pulled the radio and the climate control out to check the bulbs but i'm not sure how to get to the bulbs. Is there an easy way to take them apart to check the bulbs?
EinST's Avatar
March 3rd, 2012, 10:47 AM   #4
There are no user-serviceable bulbs (LEDs actually) in them. They usually outlast the device they are found in but do burn out or their driver circuitry do from voltage spikes. They are tied to the instrumentation illumination (not to be confused with the courtesy lighting) and thus it could be a wiring issue. If it's important to you, consider a visit to the service department.
Tags
Sponsors
