Notices
2008 crew cab - 20 inch vs 17 inch
Old December 13th, 2008, 8:43 PM
upsidedown's Avatar
Default 2008 crew cab - 20 inch vs 17 inch
I have a 2008 Chevy Crew cab 4x4 LTX, w/20 inch factory rimswith what i'd call of a street tread. Can I put 16 or 17 inch rims& tires on it that have more of an aggressive tread.
Also, gas milege on this truck is really bad, it's averaging 12-14 mpg. I previously had a 2004 Chevy Cab 4x4, LTZ that average 16 mpg.
thx
Old December 14th, 2008, 11:20 AM
bubba33's Avatar
Default RE: 2008 crew cab - 20 inch vs 17 inch
MPG sucks on mine too. Try trading with someone who has 18 Z71 wheels and tires.
Old December 15th, 2008, 11:59 PM
BassinProf's Avatar
ORIGINAL: upsidedown
Why wouldn't you be able to to put on a smaller wheel? Bottom line, the size of the wheel doesn't matter, it's the diameter of the tire. If you put on a 16" wheel you'll just need to put on a thicker tire that has the same diameter as the original tire unless you want the speedo to be off. In my opinion, an aggressive tread on a 16" rim looks a whole lot better on a truck than the 20" rims with the pansy-*** street tires that some people run, but that's just my opinion.
Old December 16th, 2008, 2:44 AM
holyspatulaboy's Avatar
i second bassin... on the meaty vs streety.... but dont go no smaller than 16, the 15s wont fit due i belive due the lower ball joint atleast thats how it works with the 99 up style.. im sure it carried over...to your style
Old December 16th, 2008, 7:14 AM
bad2006z71's Avatar
NBS (05-07classics) and NNBS trucks can only go down to a 17" rim size due to the brake sizes. 16" wheels will not fit. i personally hate 18" or larger wheels on a 4x4 truck. keep it at 17" the tires will be cheaper too. now on a street truck or say an ss silverado then yes 20" look great. although the 18" on the NNBS trucks doesnt look to bad.
good luck
Old December 17th, 2008, 12:32 AM
im sorry i stand corrected... i didnt realize that it had changed even more agian.
Old December 17th, 2008, 6:59 AM
upsidedown's Avatar
Thx for the input, I'll either trade or sellthe 20 inch rims and put on the 16's or 17's. I agree, the look and functionality of the heavier tread is much better.
Old December 17th, 2008, 7:13 AM
bad2006z71's Avatar
"upsidedown": im pretty sure you cant run 16" on your 08, 17" or bigger only, you might want to check and confirm. good luck
Old December 20th, 2008, 7:09 AM
Chas1955's Avatar
My 2007 NBS came with 17"s & I installed 20"s. I didn't think I needed to get the computer reprogeamed since they were almost the same diameter! Boy was I wrong. After talking to a friend who works in the service Dept. I had them program it & the truck ran better & got better milage by about .3mph . Also one dealer told me I didn't have to do it, but like I said it did make a difference. So from 20's to 17's check with a GOOD dealer as they are not all the same!
Old December 20th, 2008, 11:49 PM
BassinProf's Avatar
ORIGINAL: Chas1955
So what did you need reprogramming for? Did you change your overall tire diameter, or just the rim diameter? If you kept the tire diameter the same there's no reason for reprogramming is there?
Quick Reply: 2008 crew cab - 20 inch vs 17 inch
