Notices
Sponsored by: DashLynx
Old July 23rd, 2015, 5:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Brakes
Print Wikipost
2008 Silverado cruise control is not working
Old August 31st, 2011, 9:22 PM
  #21
ccook's Avatar
I still had 1 occasion where the main vent wouldnt work. I think it was just blowing down by my feet and wouldnt switch back. It only did this once thought and has been fine ever since. everything else is straight except now the remote start doesnt work. this isnt a huge deal and I plan to have it fixed at my next oil change. Thanks for asking.
Old March 10th, 2013, 8:17 PM
  #22
woosch's Avatar
Default 2008 Silverado Cruise Control Fixed
I have a 2008 Silverado LTZ 2500 HD Diesel. I was having cruise control problems. At first i thought that it was the cold weather, because it would work fine after the truck was warmed up. It finally quit working all together but the light on the steering wheel was still on. I replace the switch on the brake pedal and it solved the problem. The part number was A/C Delco# D1586H, GM# 15861245. All you need is a 10mm wrench and a small screwdriver to pry the clip apart. I hope that this helps.
Old March 12th, 2013, 7:54 PM
  #23
woosch Welcome to the forum
Thanks for the helpful info on the part numbers
Old May 29th, 2013, 1:42 PM
  #24
ram49's Avatar
Default 2008 Silverado cruise control.
I pressed on the set button and a the same time kicked the brake pedal a
couple of times and the cruise came on. What is involved in changing the brake switch ?
Aaron Sanford (May 16th, 2021)
Old June 4th, 2013, 11:15 PM
  #25
Poncho_villa's Avatar
2007 Silverado 4x4 5.3 automatic and I have this same condition. I guess it's time to change out that switch. "I replace the switch on the brake pedal and it solved the problem. The part number was A/C Delco# D1586H, GM# 15861245. All you need is a 10mm wrench and a small screwdriver to pry the clip apart. I hope that this helps." Thanks for the info Woosch
Old June 5th, 2013, 8:26 AM
  #26
coogdad's Avatar
I also changed the brake switch on my 08 silverado. Fixed the problem with cruise control.
Old June 6th, 2013, 12:31 PM
  #27
ram49's Avatar
I have a switch on order. Thanx for the info
Old June 30th, 2013, 12:38 PM
  #28
Fatcatbrat14's Avatar
2008 2500hd 6.0 4x4: just replaced the brake switch and the whole cruise control switch (had to pull airbag off)...still no cruise control.
Old July 14th, 2013, 3:50 PM
  #29
ram49's Avatar
I got my new brake light switch and replaced my old. I'm happy to say that my cruise control works just fine now. Thank you for all the info..
Old October 3rd, 2013, 3:45 PM
  #30
stu carlon's Avatar
Installed new switch. Still having issues. Need to dig deeper. Hope its not button on steering wheel.
Quick Reply: 2008 Silverado cruise control is not working
