Notices
starter clicks once
Old April 8th, 2011, 11:59 AM
cumminbr's Avatar
Default starter clicks once
Hey guys, I am the new owner of a 1989 c2500 and I just replaced the radiator and now it won't start. The starter just clicks once. Please help.
Old April 8th, 2011, 1:42 PM
sounds like worn starter brushes. have someone hold the key to start and tap the starter sharply with the butt end of a long pry bar or tap with a hammer. stay clear of moving parts!!
Old April 8th, 2011, 2:04 PM
cumminbr's Avatar
the starter is under the engine, in front of the transmission, right?
Old April 8th, 2011, 2:14 PM
should be on the right side under the exhaust manifold. might be able to access it through the right wheel well if you pull the rubber shield up. If not access either top right side of engine compartment or under the truck on the right side.
Old April 9th, 2011, 8:54 AM
basilkies's Avatar
Also could be an old battery going bad or a poor corroded connection at the battery post(s).
Old April 9th, 2011, 11:02 PM
OLD WRENCH's Avatar
You didnt chg thermostat and leave the ground wire off did you.
Old March 13th, 2012, 9:22 AM
rancher936's Avatar
Did you ever figure out your starter problem? I am having same problem on a 1995 chevrolet 350 silverado. Thanks,
Old March 15th, 2012, 3:17 PM
cumminbr's Avatar
The starter was just stuck. I tried to take it out to test, but put it right back in and it started up.
tracerbullet
December 6th, 2012 2:49 PM
cdbrock24
September 13th, 2010 6:01 PM
69355
June 13th, 2009 6:17 PM
sethlives1
Cobalt
October 7th, 2007 7:39 PM
02rubio
August 22nd, 2007 7:30 PM
Quick Reply: starter clicks once
