2010 2500 - Silverado - Rattling upon excelleration and at speeds over 75
I am experiencing a rattling that appears to be coming from the passenger side of the enging that only happens when hard excelleration 0-50 and at speeds over 75. I have changed the belt tensioners as well as checked the fan shroud. Any ideas of other things that could be causing the rattle?
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> gmhigbee,
Have you been able to resolve this issue? The vehicle is still under warranty correct?
Louis
GM Customer Service
Louis
GM Customer Service
Official GM Rep
I have researched my resources and there are currently no known issues, based on your description. I encourage you to consult with a certified technician for an inspection. They should be able to offer additional information after inspecting the vehicle.
Please keep us posted.
Louis
GM Customer Service
Louis
GM Customer Service
thisnthat
November 20th, 2012 11:36 AM
