Notices
2010 chevy silverado radio problems
Old January 28th, 2016, 9:40 AM
  #11
Weavergj56's Avatar
Default Aux input device problem with radio
Originally Posted by johnrmaples
Mine is doing the same thing. The radio will be playing, then suddenly silence and displays "Aux Input Device". Back and forth between radio and this. I almost cannot listen to the radio any more. Doesn't matter if I push the Source button, turn the radio on/off, nothing.
Advice???
I have a 2013 Silverado and it's doing the same thing too! Getting really frustrated with the radio keeps switching to Aux Input Device and I'm not even using it! I touch the band button and radio comes back. If I'm listening to XM or CD or Radio doesn't make a difference It will bump off multiple times during a song. Seems to be a problem with other peoples radios as well from what I'm seeing on this forum
Old January 28th, 2016, 9:51 AM
  #12
Weavergj56's Avatar
Default Radio Input Device Problems
I have a 2013 Silverado and it's doing the same thing too! Getting really frustrated with the radio keeps switching to Aux Input Device and I'm not even using it! I touch the band button and radio comes back. If I'm listening to XM or CD or Radio doesn't make a difference It will bump off multiple times during a song. Seems to be a problem with other peoples radios as well from what I'm seeing on this forum. Not seeing a resolve for this problem.
Old February 13th, 2016, 9:57 AM
  #13
AM180OUT's Avatar
Same problem with my 2010.
After using the aux input jack (bottom right) with an ipod the jack is making intermittent contact now with no plug in it. A good smack on the radio makes it work for a while. I'll be trying some electronic cleaner and exercising the jack a few times today. Unsure if you can get to the jack with the radio removed. Anyone tried this?
Old August 26th, 2016, 7:59 PM
  #14
85Z28's Avatar
Same issue with the radio in 2010 Malibu. Aux Input Device flashes on and off constantly - impossible to listen to radio or CD or anything. Has anyone found anything that fixes this?
Old August 27th, 2016, 4:52 AM
  #15
robpaulson's Avatar
Same problem. I used a audio cable and plugged it into the aux port. It's not attached to anything but aux port. No problems anymore.
Old September 25th, 2016, 10:23 AM
  #16
85Z28's Avatar
Default Resolved
Thanks a bunch! I plugged old headphone cable in and out of aux port several times before it totally cleared up. I'm now able to listen to my radio/CD without any problems. For good measure I used some canned air on it.
Old March 24th, 2018, 10:50 AM
  #17
Bruce Jones's Avatar
My radio switches to "Aux Input Device" for no apparent reason. Some times it will switch back to the radio on its own, but most of the time I have to do it manually. Any help would be appreciated. Thanks
Old April 4th, 2020, 11:21 PM
  #18
MoeMoe Montoya's Avatar
Default Display
My issue is different. When I turn the truck on the radio and display will come on. Eventually the display will turn off and the radio will continue to work. Sometimes the display will turn back on. It’s a bit annoying.
Old June 18th, 2020, 7:10 AM
  #19
cacaface's Avatar
so i take it, that there is no actually solution for this?
i see some have removed the radio and checked all plugs, for those who have, did it fix your issue?
charlie pachanga
March 16th, 2013 3:56 PM
tim68rsss
Silverado & Fullsize Pick-ups
August 28th, 2010 2:52 PM
spoiler429
June 18th, 2010 12:22 PM
brdfixr
12
June 10th, 2010 2:04 PM
adamant
February 15th, 2009 8:49 AM
Quick Reply: 2010 chevy silverado radio problems
