2011 silverado is possessed
I have a 2011 silverado rocky ridge. I took my battery out this past summer to put it in my boat. Well, it didnt work out as planned so I put the battery back in truck.. Well ever since, my truck is possessed.
At night, I hit my brake and my lights dim. A lot of times when i brighten my light, my radio will completely shut off and then restart. During the day, if im running my ac, i can turn my blinker on and the radio will die.
Its like everything is fine until I do something that needs more power (blinker, bright lights, etc) it has gotten to the point where when my radio shuts off, my stabil trak light will come on. - also, often when i cut my truck off, the radio will shut off before I open drivers door..
I started off by checking the connection. I disconnect battery and master fuse and used steel wool to clean all connections, then even added a touch of grease, It worked for about a week, then problem continued. I just bought a new battery and I thought the problem was solved until last night I was driving and brighten my lights and then the radio shut off....
Now Im thinking maybe change battery cables or get a new alternator....
Im about to pull my hair out on this one!!! Any ideas????
ChevyGirl94
Silverado & Fullsize Pick-ups
January 13th, 2010 8:04 PM
augr
February 28th, 2008 1:28 AM
