Notices
Sponsored by: DashLynx
4.3L starting issues need help
Old February 26th, 2012, 7:51 PM
bigj2201's Avatar
Default 4.3L starting issues need help
I have a 2003 silverado base model 4.3l v6 144xxx mi. Which has recently come into some starting issues this is what I've replaced so far
Fuel pump
Fuel filter
Fuel pressure regulator
I've cleaned my maf sensor I've also replaced my air filter...I thought for sure the regulator would of done it but I guess I was wrong if I want to start my car I have to hold the gas pedal in then crank on key??? Any help would be sweet
Old February 27th, 2012, 6:16 PM
Fishinfooleric10@aol.com's Avatar
well that just sucks. Here's a question after cranking on it, does it start and die, or if it does run is it shaky or missing or anything?
Old February 27th, 2012, 10:19 PM
bigj2201's Avatar
it starts if i press on the gas pedal then its gets shaky for about 5 seconds and then its fine till i shut it off and start it again
Old March 1st, 2012, 5:18 PM
Well, you might have a vacuum leak or also you can check your throttle body to make sure its not all nasty and stuff in there, but it seems like the hard starting would be due to a vacuum leak. Sorry i dont have more help
Old March 25th, 2012, 11:54 AM
New User
Awaiting E-mail Confirmation
dandelli's Avatar
Default v6 starting issues
Has anyone out there had any issues with starting a silverdo v6 after doing a lower intake gasket? The timing is correct,there are only two ppsistions for the distributor to drop and the oposite side drop will not even crank. There is a funky car lock symbol that is coming on the dash after 7 or 8 cranks. Any help please?
ironhead1974
February 22nd, 2020 10:03 AM
sabinandmary
February 21st, 2012 10:55 AM
jeffwest5599
January 5th, 2008 11:09 PM
99 on dubs
December 29th, 2007 12:17 AM
Quick Reply: 4.3L starting issues need help
