4 wheel drive binding going straight
Hey I have a 2006 1500 silverado with push button four wheel drive. When I put it in 4 hi and try to drive it acts as if the front diff is binding up. Then when I put the transmission in neutral and put the t case in 2 hi the truck jumps and makes a big clunk. Also the t case makes a squealing noise in 4 wheel drive when you lift it up on a hoist and turn the rear drive shaft. Is it something in the t case causing all this or a combination of both? Any input would be much appreciated. By the way I only have to move about 20 feet to get it to bind up going straight no turns. Thanks y'all.
Noise
Check the oil in the transfer case. Electronic push button take Auto-Trak II blue fluid. Hand shift take regular tx fluid.
Allan
jchcomputers
Silverado & Fullsize Pick-ups
August 8th, 2009 12:01 AM
SuperTexan
10
October 8th, 2007 11:53 PM
