Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Current Chevy Trucks, SUV's, Crossovers & Vans > Silverado & Fullsize Pick-ups
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Search Today's Posts Mark Forums Read Used CarsGarageVendors TSB & Recalls
Search
Welcome to Chevrolet Forum - Chevy Enthusiasts Forums
Sponsored by: Bakliner
LinkBack Thread Tools
Old 11-20-2010, 12:34 PM
Default 4 wheel drive problems please help
hi there. i have a 2006 gmc sierra 5.3l Z71. im having issues with my four wheel drive. while driving down the highway i noticed some noise almost like a howl, when i shirt into 2wheel it goes away. also while trying to turn around it seems to really bind up hard if i stop 3/4 of the way thru the turn ill shift it into 2 wheel all the binding and pressure just releases and i can fully turn around. any imput would help me out thanks. chris
Register today for free or log-in if already registered to remove this ad!
Old 11-20-2010, 03:00 PM
2wd-K5's Avatar
1979 Chevrolet Blazer
are your tires worn unevenly? this is a big thing with 4x4's if you dont rotate your tires, the fronts wear much faster than the rear and create an uneven tire combo for the system, u can blow the transfer case by driving like that, if it is the case
__________________
1979 2wd k5 blazer- parked and will have engine pulled and original put back in and sold
coming soon: rebirth of an 81 malibu coupe
fast - cheap - reliable: pick 2
Old 11-22-2010, 11:00 AM
1997 Chevrolet C/K 1500
is it going into 4wd by itself?
Old 11-22-2010, 11:11 AM
Default towing on 1976 1ton dually
what is the towing capacity of a 1976 reg cab 4x2 1ton 454 dually for conventional towing and 5th wheel towing
Old 11-23-2010, 09:49 PM
no i shift it into 4wd.
Old 11-23-2010, 10:13 PM
gotstylez's Avatar
1995 Chevrolet Silverado 1500
agree with 2wdk5 on the howl.....and the 2nd problem from what i read on the post its normal..if u put anything into 4wd and turn sharp..it'll bind up
__________________
Davey
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my ride." -Amen
Quote:
Originally Posted by RacerX View Post
. Yukon doesnt have the same familial feel as "I was in a Jimmy pulling hogs"
Old 11-24-2010, 12:49 AM
WOAH... dont drive down the highway in normal conditions four wheel drive. axel ratios front to rear are not the same and will screw up your gears in the front. as for the grinding,thats because the front wheels turn together and when you turn, the outter wheel wants to turn faster then the inner wheel to make the turn, thus making it bind.. 4wd is for slippery applications where grip is needed, not already there. otherwise use 4wd auto
__________________
Z71 RULES
Old 11-29-2010, 03:55 AM
Quote:
Your joking right? Tell me your not running 4wd at highway speed on dry conditions!!! If you are good luck!
Old 12-01-2010, 09:39 AM
thats why i asked if it was going into 4wd by its self because i assumed you werent doing it and then driving on the highway, your going to mess some serious stuff up like that
Old 12-03-2010, 04:47 PM
From the 2005 GMC Owners manual: Avoid driving in four-wheel drive on clean dry pavement. It may cause your tires to wear faster, and make your transfer case harder to shift and run noisier.
No big warnings about different axle ratios and all that stuff...
Tags
05, 2000, 2005, 4w, binds, blazer, chevrolet, chevy, drive, front, gmc, howls, problems, put, shift, silverado, truck, turning, wheel, wheeldrive
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
