Loss of oil pressure
WE ARE IN NEED OF SOME HELP. WE HAVE A 95 CHEV SILVERADO PU/350 ENGINE 4X4 THAT JUST HAD THE INTAKE MANIFOLD GASKETS REPLACED. IT WAS STARTED IN THE SHOP AND RAN FOR SEVERAL MINUTES AND THEN DRIVEN AROUND THE BLOCK A COUPLE OF TIMES AND ALL WAS GOOD. WE PICKED IT UP AND DROVE IT HOME, ABOUT A 25 MILE TRIP. CLOSED TO THE END OF THE DRIVE HOME IT LOST A LOT OF OIL PRESSURE. IT DIDN'T DROP TO ZERO, BUT IT DID DROP TO 20. IT'S NORMAL RANGE IS AROUND OR AT 60. I DO KNOW THERE ISN'T ANY WATER IN THE OIL OR AT LEAST IT DOESN'T LOOK LIKE CHOCOLATE MILK. CAN ANYBODY TELL ME WHAT COULD HAVE CAUSED THIS AND WHERE TO LOOK NEXT TO FIX? THANKS
Also you could do better with info, for instance why did you replace the gaskets? If it was because your enging overheated then you could have warped heads and gasket won't solve the problem.
not_a_car_dude
September 15th, 2013 7:41 PM
drbydriver
December 23rd, 2012 2:13 PM
