Notices
Sponsored by: DashLynx
95 1500 fuel regulator options needed
Old September 6th, 2012, 10:05 AM
Rado95's Avatar
Default 95 1500 fuel regulator options needed
Looking to upgrade fuel regulator. Any recommendations? Adjustable type?Adding spacer soon.
Old September 6th, 2012, 11:25 AM
chevyboy1993's Avatar
i've seen many adjustables ones online but never bought any. jet has one. i just did a spacer on the regulator spring but the only problem is, tbi's only run around 10-13 psi stock and the stock fuel pump maxes out at 15 so if you wanna go higher than that you need an upgraded fuel pump also
Old September 7th, 2012, 9:20 AM
Rado95's Avatar
Thanks for the reply. Read somewhere that a spacer might need the 13 psi.
Old September 7th, 2012, 10:31 PM
i'm running the full 15 psi in my truck right now. had a different fuel pump before but it burnt out so i had to put the stock back in. with the aftermarket fuel pump i was running 24 psi using a 1/4" worth of washers. ran like a raped ape
solerano
September 1st, 2013 5:26 PM
Tahoe Joe
August 16th, 2009 4:48 PM
momto5
January 5th, 2007 10:16 AM
momto5
January 4th, 2007 10:46 PM
97metro
August 12th, 2006 11:02 PM
Quick Reply: 95 1500 fuel regulator options needed
