Notices
95 chevy truck running to cool
Old May 13th, 2012, 5:51 PM
ncsouthpaw's Avatar
Default 95 chevy truck running to cool
My 95 chevy doesn't get up to 195 degrees, temp of thermostat. According to the temp gauge it is running around 150 degrees. I have checked it with a separate thermometer and it appears the gauge is correct. My understanding is if it runs cold the computer will keep it running in cold mode and gas milage will suffer. Any suggestions welcome.
Thanks Ronnie
Old May 13th, 2012, 6:21 PM
Did you check to see if it has a thermostat and what temp it is?
Old May 13th, 2012, 7:00 PM
cleveland63b's Avatar
tstat may be stuck open or completely missing depending where you live or who had the pickup before you
Old May 13th, 2012, 8:53 PM
ncsouthpaw's Avatar
I have had the truck since 97 and it has a 195 degree thermostat in it. My first thought was it is stuck open, I put a new one in it and checked the old one and it semed to be working ok. I forgot to mention that it is a 5.7 engine, if that helps any.
Thanks Ronnie
Old May 13th, 2012, 11:03 PM
EinST's Avatar
Does yours have an ECT sensor (for the PCM) and a separate ECT sender (for the I/P cluster)? If so, I'm not sure where you measured the temperature but you may not have anything to worry about. It's not likely that two difference thermostats show the same "symptom."
Old May 14th, 2012, 9:30 PM
ncsouthpaw's Avatar
I am not sure I know what the ECT sensor is or the I/P cluster. I measured the temperture with a thermometer in the radiator.
Old May 14th, 2012, 9:39 PM
EinST's Avatar
Pardon me, ECT is short for "engine coolant temperature" and I/P, "instrument panel." And, a thermometer in a radiator is not really a good way to measure the temperature of the coolant where it counts (near the thermostat). Is the issue something new to this vehicle or are you just fishing?
Old May 14th, 2012, 10:13 PM
Professional Mechanic
MDTAHOE's Avatar
Does the truck have plenty of heat? Take the temp of heat coming out of vents. Does that temp drop when driving.
Old May 14th, 2012, 10:50 PM
1BDDELX's Avatar
Just to throw my .02 in my tahoe gauge always read around 150 but my hand held scanner shows the computer is getting the proper temp reading of 195 or whatever temp t-stat I put it in awhile back. I would assume the gauge on mine is taking temp from a different spot then the computer. Maybe possible thats what yours is doing.
Old May 15th, 2012, 7:20 PM
theres usually a sender for the gauge and a sender for the pcm
Quick Reply: 95 chevy truck running to cool
