97 1500 Express Starting/Stalling problem
Hi guys. I have been spending a lot of time on here as a guest. I appreciate all the information provided. This question is a bit more unique. I Have owned this truck for about a year. At about months of owning it, I have noticed it took more than one or two starts to actually get it going. I then have started seeing the fuel gauge bounce as I was driving it. As time progressed the vehicle went from 2 or 3 cranks to start, to 3 or 4. If it was cold (i live in michigan) I would have to grab the ether to start it. Once started and ran the truck wouldn't have any problem starting up. I have also noticed, sometimes the fuel gauge would be bottomed out either while started or just with the key turned.
Okay, now with the real big issue. Today, I had tried to start it. even with the ether, it still wasn't starting. I finally got it going and went to drive off. It stalled as soon as I gave it gas. Startedd it again, fired right up, drove off and pull out onto the street. I went to accelerate and it stalled complety at about 25mph. took forever for it to start again. I let it run for about 15 min and tried to drive off it drove fine under 25mph but once i gave it gas it just would die. I would pull off the gas and once it was under 25 and the engine was back running.
Everytime I turn the key I can hear the fuel pump turn on. after about 20 times of it tuning on it stopped. Normally it always turns on. I replaced the fuel filter. I also read there is another filter on the pump and I have not changed that. Any suggestions?
Mark
Mark
cnvh
Silverado & Fullsize Pick-ups
March 10th, 2014 7:43 AM
Danman2897
November 1st, 2012 4:26 PM
Danman2897
October 31st, 2012 9:37 PM
flipme198922
Express & G-Series Vans
July 22nd, 2012 9:29 AM
