Trouble with tow light
Have 2005 Chev 4x4 that is giving me some quirks. First started with the temp guage working intermitently and when this happens the "check engine" light sometimes is on. When these two are not working properly the tow/haul button will only work when in P or N. In otherwords I can put the button to turn tow/haul on in P or N but when I put it it any gear I can'not turn it off or on. If it was off when I put it in gear it won't turn on, if it was on when I put it in gear it won't off.
Any ideas?
Any ideas?
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> praaa_5,
I would like to look into this issue further for you. Could you please PM me your VIN number so I can check if there is additional information available?
Is this a recent occurrence or has it been happening for awhile? Have you taken the vehicle in for an inspection for this issue?
I look forward to your reply.
Louis
GM Customer Service
Louis
GM Customer Service
topwhop1977
Silverado & Fullsize Pick-ups
January 3rd, 2012 2:11 PM
dozer157
September 8th, 2009 7:32 PM
