Notices
97 5.7L Silverado. Oil Cooler lines, which goes where on rad?
Old June 19th, 2012, 8:35 PM
jgray152's Avatar
Default 97 5.7L Silverado. Oil Cooler lines, which goes where on rad?
Hi Guys
I have oil cooler lines coming from the oil filter housing, the OUT line from the filter housing is running to the bottom of the rad and the IN line is running to the TOP of the rad....Should I reverse these lines? I'm getting a deep knocking during start up and wondering if its from the oil lines....could also be something with the flywheel since this has a tinging which comes directly from the flywheel bell housing
Old June 20th, 2012, 6:47 PM
96 Junk That Moves's Avatar
Sounds like one of the flywheel bolts has backed out and is litely kissing the back of the block. Pull the flywheel inspection cover and check it out...easy fix...I could be wrong though. Noises are a process of elimination.
Old April 10th, 2014, 9:23 AM
Ididit86's Avatar
Forgive me.. I am a newbie. Mine is making a noise that could fit this bill as well.. I remember pulling the inspection cover to check for a leak of the rear main (ended up being leaky oil cooler lines) and if I remember right, I could barely see inside. I would like to check my fly wheel bolts as well, I have two questions; 1. Does this sound like the same cover you are referring to and 2. Can you inspect and tighten the bolts if loose from here or does this require transmission removal from this point? For the life of me, I cannot remember why I could barely peer in there, this was not on a lift mind you, it was a jack stand/from the back attack... Thanks
Old April 11th, 2014, 9:18 AM
Fishinfooleric10@aol.com's Avatar
There is a plastic cover by your starter that is an inspection window for the fly wheel. You do not need to remover trans, just remove the plastic piece.To get to all three of em, have truck in neutral and you can use a pry bar to rotate the flywheel or however you want to make the flywheel turn. Once you do this then you can inspect all flywheel bolts. I believe that yall are talking about bolts that hold torque converter to flywheel because you said touching the back of block. Hope this helps you out
Old April 12th, 2014, 9:56 AM
Ididit86's Avatar
Hey thanks Pal. I will check that out. Appreciate it.
Old April 12th, 2014, 11:31 AM
Allan In NE's Avatar
Cooling oil always runs from bottom to top at the radiator.
Allan
NoFear50
September 16th, 2015 7:13 PM
MikeT
February 2nd, 2015 3:14 PM
flyhound
February 2nd, 2014 6:56 AM
usmarine0905
November 25th, 2011 4:30 PM
zagfan1989
September 27th, 2011 12:42 PM
Quick Reply: 97 5.7L Silverado. Oil Cooler lines, which goes where on rad?
