98 1500 wont start after intake gasket change - Chevrolet Forum - Chevy Enthusiasts Forums
Sponsored by: Bakliner
danweir6's Avatar
March 14th, 2011, 5:39 PM   #1
i swapped out the gaskets cause they were leaking coolant.
i have good spark, lots of fuel(maybe to much) plugs come out soaked.
will fire a little bit but not enough to run.
checked #1 cylinder is at tdc when distributor is firing #1 spark.
i have a snap on diagnostic tool but what can i do if it wont run.
help please
norcalstew's Avatar
March 16th, 2011, 10:20 PM   #2
I've got the same problem. New intake gasket, went great. However I have no spark. I did the same as you. #1 tdc. on compression and the rotor pointing at #1 post on cap. Scatching my head, my buddy came by and said there is marks on the lower shaft of the distributer that line up before dropping it into the motor and the rotor will end up pointing at the # on the dist. housing at the top. I'm confused bet he is bringing me a book tomarrow. If it works for me I'll pass it on to you.
OLD WRENCH's Avatar
March 17th, 2011, 11:50 AM   #3
wont start
Sounds like you have one of the rare buddys that knows what he's talking about.
Tags
Sponsors
