98 K1500 Z71 Power Window Problem
Ive had the truck a few weeks now. When i bought it the driver side window would roll down but had to mess with the switch quite a bit to get it to roll down. Now the driver window will not go down at all, but I can still control the passenger side window from the switch on the drivers side door??? Does this sound like my switch is bad or the motor in the driver window? I dont wanna just buy parts and change them without knowing what my problem is for sure. Thanks for any help
Driver side window is used more than any others. Probably the motor. I've not looked at cost, but I'd say after market $25 or so? This model may require the regulator also, I just looked at Dorman, about 80 bucks for both. I don't know your location, but I'd check autozone, napa, O'rielleys
98 Chevy Master Window Switch
Most places wont let you return anything electrical if it isn't the issue. However here at switch doctor you have a 30 day return policy and if the switch isn't the issue you can return it within the 30 days. http://www.switchdoctor.net
did you find a solution? I’m having the exact problem
1994medtec
Silverado & Fullsize Pick-ups
January 11th, 2012 2:01 AM
davbell22602
March 10th, 2010 8:36 PM
DrummerBoy
October 17th, 2009 10:20 AM
