98 Silverado fuel injectors SCFI vs MPI
I am assembling my freshly remaned 350 vortec and want to replace the old injectors. Whats the benifits of this new MPI injection ive heard about? Is it worth the money to upgrade? I found this set up on Amazon -Delphi FJ10566 Fuel Injector $271. Is this a good one to go with?
1-the poppets can stick closed causing a missfire on that cyl(mine jammed closed causing a dead cyl)
2-they stick open causing missfires and poor running
3-the old regulator can leak dumping fuel into#5 and#7 more running problems
4-they can intermitantly stick causing misfire to come and go
5-mine ran smoother
6-it will give you problem in the middle of winter (thats my luck)
hang the old one on the wall and wonder what the F@#$ was GM thinking
5-mine ran smoother
I have a 96 with sticking poppet valves. MMO in the gas helps but I will upgrade. If you are assembeling a new engine do yourself a favor and upgrade from the start.
Just my HO
Just my HO
Colt Hero
April 30th, 2008 4:03 PM
art
Silverado & Fullsize Pick-ups
April 9th, 2007 4:48 PM
