Notices
98 silverado transmission
Old March 5th, 2014, 9:25 AM
5 Alive's Avatar
Default 98 silverado transmission
I screwed up! Replaced my radiator the other day and must have lost a lot of transmission fluid. Drove to work just fine then going home third gear stated slipping. Checked the fluid level and was very low so I added Lucas slip stop to top it off but third gear just wont catch. Reverse, first and second are fine and there is no trans fluid in the radiator. I know a diagnosis over the internet is hard but what should I expect to hear from a mechanic? Parts, rebuild, new transmission? thanks
Old March 7th, 2014, 7:30 AM
davedriveschevy's Avatar
Did you top off trans with it idling in park on a level surface? Are you 100% sure that its full? You will get a lot of false readings on the dipstick immediately after adding fluid due to residual tranny fluid in the dipstick tube.
And dont bother with the tranny in a can crap, just add the correct fluid. If it is slipping, nothing in a can is going to replace the missing friction materials on the clutches.
Coravir
October 26th, 2019 3:28 PM
DSGB
May 29th, 2013 8:54 AM
cgcomeaux
January 16th, 2008 5:39 PM
ibmoses
December 9th, 2006 10:48 AM
fixen
October 20th, 2006 8:10 PM
Quick Reply: 98 silverado transmission
