99 rodo z71
99 rodo z71
How much play is in transfer case ?? I get a thud so jacked truck up rear end is OK . The play is from transfer case .the ujoints look good
How do I open and look at chain and if floppy what's needed
grammar and detail would be helpful but there shouldnt be much play in the tcase itself, pull the plugs check the fluid and if you can see inside rock the driveshaft back and forth see if you have a floppy chain
jgray152
Silverado & Fullsize Pick-ups
February 19th, 2012 11:12 AM
