Notices
Sponsored by: DashLynx
99 Silverado hard to start when warm
Old March 1st, 2010, 8:59 PM
jgore43's Avatar
Default 99 Silverado hard to start when warm
Hey guys,
My silverado is easy to start first thing in the morning and right after shutting down. If i let it sit after warming up, it takes 3-6 sec to start up. For the first 100k miles it was perfect. Ive already changed all filters and spark plugs,its a 5.3l v8, 2wd, ext cab. What do y'all think, i'm a relative noob to most maintenance.
Old March 1st, 2010, 9:37 PM
bsballfn172's Avatar
What does it sound like when it doesn't start up right away? Does it just sound like it's not getting fuel or is it something else?
Old March 2nd, 2010, 5:55 AM
jgore43's Avatar
it sounds like its not getting fuel and its having a hard time pulling it from the tank.
Old March 3rd, 2010, 6:07 AM
and it's not leaking anything anywhere?
Old March 3rd, 2010, 8:43 AM
maxxman04's Avatar
sounds like vapor lock, tho the vent lines are supposed to prevent that. unless evap solenoid is stuck or clogged
Old March 3rd, 2010, 3:19 PM
jgore43's Avatar
I thought i 'd reword whats happening. The engine cranks a lot longer than usual, and is kind of rough starting up. Once it is going, though, the truck runs just fine. The truck operates just fine. There are no discernible performance losses or hesitation upon acceleration. Ive been perusing the Google and other forums have pointed to fuel pump. Could that be a possibility? Also there are no leaks as far as i know, will go have another look now.
Old March 3rd, 2010, 4:26 PM
maxxman04's Avatar
check the idle air control valve, clean it if dirty. it's mounted on the throttle body.
Old March 4th, 2010, 4:52 PM
jgore43's Avatar
thanks yall , i cleaned the idle air control valve and as far as i can tell it has solved the problem, starts just like when i bought it.
Old March 4th, 2010, 5:06 PM
maxxman04's Avatar
glad to hear ya got it fixed. amazing what a few minutes of cleaning will do.
lilrebel
November 6th, 2010 9:47 PM
midnightrumbler
June 27th, 2010 3:47 PM
isrblue
June 14th, 2010 7:36 AM
aman721
February 3rd, 2008 4:12 AM
redbeard
Computer, Ignition, & Fuel Systems
August 5th, 2007 1:33 PM
Quick Reply: 99 Silverado hard to start when warm
