Notices
Sponsored by: DashLynx
95 GMC misses/runs rough after warmup
Old October 17th, 2006, 11:22 AM
buster's Avatar
Default 95 GMC misses/runs rough after warmup
Hey people
I have a 95 GMC c1500 pickup w/5.7 & auto. The problum is as follows. When staring with a cold engine it runs fine but, as soon as the engine warms up to operating temp (only a couple of minits) it will hesitate/stumble around 1200 to 1800 RPM yet it will idle just fine. It does not matter weather it is under a load or not. Check engine light is not on & has no codes present. It was doing this when I bought it with 161000 miles. have replaced the following mostly because it really needed it; cap, rotor, coil, plugs, plug wires, map sensor, tps, fuel filter. Also have checked the engine gound wires & checked for vacuum leaks. Since it runs smooth at idle I don't beleive it has vacuum leaks. The spary pattern for the injectors seems to be fine. I have not checked fuel pressure but since it accelerates fine under full thottle I did'nt think theres a problum with the pump. Is anyone here familar with these symptoms? Are there common issuses with the base plates wearing out on the throttle body? Or do the distributor bushings wear out? Im stumped!!!
Old October 17th, 2006, 7:45 PM
carpenterbill's Avatar
Default RE: 95 GMC runs rough after warmup
check the EGR valve, sounds stuck open to me but I could be wrong.
Old October 18th, 2006, 1:27 AM
99Silverado's Avatar
I have a 99 with the same set up. I do have a Service Engine Soon light on. Mine is making the same problem. Autozone checked it and said I need a new catalytic converter.
Old October 18th, 2006, 2:33 PM
buster's Avatar
thanks for your responce guys, to Carpenterbill---- I have been courious about the EGR system, I can move the EGR diapharm with my finger but I know it is not a good test. to 99silverado----- since my truck accelerates fine under full power logic tells me the cat converter is not blocked , and as for the guys at AutoZone----- are you really going to trust what they say????? All they are good for is giving codes.
Old October 20th, 2006, 9:13 PM
buster's Avatar
anyone else ??????
Old November 6th, 2006, 4:28 PM
buster's Avatar
try again
Old March 16th, 2008, 5:01 PM
95gmcyukon's Avatar
my truck is doing the exact same thing. 95 gmc yukon. any suggestions?
Old March 16th, 2008, 9:42 PM
northey87's Avatar
95gmcyukon, welcome to the forum!!!
Have the injectors been checked or serviced lately?
Old March 18th, 2008, 6:44 AM
jmack91z28's Avatar
Your coil is bad. Replace the ignition coil, it's cheap too, probally $30.
Old March 18th, 2008, 10:13 AM
buster's Avatar
no the coils is not bad. I have replaced it already!
Quick Reply: 95 GMC misses/runs rough after warmup
Top
Follow Us
