Bottom end tick?
Bottom end tick?
Im looking at buying a 01 6.0 silverado with 200k on the motor. I test drove it today and when I went to crawl under it while it was running I could hear a nonrythmic ticking noise. I could not hear it on the passenger side but only the drivers and while under it. When i revved it the motor did not make any other noises. and I could not hear it worsen. Is this a common noise to the 6.0's?
Last time I had a problem with a nonrythmic ticking sound near the driver side it turned out to be a problem with my EGR valve. Granted that was on a completely different engine (3800II Series V6) but it is well worth a try just to look at it to make sure its no that. Also, I had a ticking sound in the rear right side of my Tahoe and it turned out to be a dust shield that had rusted and was hitting the moving parts of the tire. But since you said it was running and nonrythmic it sounds like it could just be a loose end and you might just need to look around with a strong/bright light. Hope this helped.
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Jimbos01hd,
I suggest you take the vehicle in for a quick inspection by a certified technician before purchase. Better safe than sorry.
Keep us posted.
Louis
GM Customer Service
Keep us posted.
Louis
GM Customer Service
avoyager
August 4th, 2013 1:00 PM
