Notices
Brake Booster Effecting RPM's?
Old February 27th, 2012, 8:19 PM
New User
Awaiting E-mail Confirmation
CodySchroeder94's Avatar
Exclamation Brake Booster Effecting RPM's?
I have noticed my 91 Chevy is lacking power in D and OD while going down the highway and when i tap my brake pedal my rpm's will shoot up suddenly from around 200-800rpms depending on the position of the throttle and how fast I am traveling but when it does this it is not shifting down, but instead just gaining the rpms could this possibly be linked to a defective brake booster? also my brake light is flashing 4 times and slow on the 4th flash idk if this is also related but I would also like to know what that is indicating
Old February 27th, 2012, 11:12 PM
avgas's Avatar
I had a 91 GMC Ex cab and from what I remember it had a vac operated brake booster. If the booster diaphram has a hole in it you will notice the engine change rpm at an idle for sure. I cant help you with the brake light flashing but if your unsure about repairing this your much better off getting a mechanic to look at it. Brakes are something you need!
Old February 28th, 2012, 9:12 PM
New User
well i have a replacement brake booster but i was just unsure if that could be the cause for my weird rpm fluctuation and im fairly capable of changing it but i was just curious if anyone had any input on anything else i may be overlooking but thank you for he help
Old February 28th, 2012, 10:54 PM
avgas's Avatar
If you disconnect the vac line and plug it and the rpm has no change when you step on the brake you will know your booster has a leak, Good luck with the booster change.
Old February 29th, 2012, 5:30 AM
when you tap the brakes at highway speed the torque convertor clutch releases; there will be a increase in rpm. this is normal.
Old February 29th, 2012, 6:31 PM
New User
and it has a large loss of power in OD and at a stop while holding my brake the brakes will slowly bleed off so im leaning to a vac leak in the booster
Lord Letto
October 24th, 2009 2:54 PM
Eric L
October 2nd, 2009 12:19 PM
tampc
May 22nd, 2009 11:29 AM
randys94
May 14th, 2009 9:39 PM
GSXJuggalo
September 17th, 2007 8:36 PM
Quick Reply: Brake Booster Effecting RPM's?
