Notices
Sponsored by: DashLynx
Old August 10th, 2015, 3:08 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Steering & Suspension Guides
Print Wikipost
Camber adjustment with wheels on
Old February 22nd, 2012, 7:41 PM
ukrkoz's Avatar
Default Camber adjustment with wheels on
Hi all.
I have about month old alignment done on my 2000 Silverado with torsion bars. I replaced lower control arms then.
I have done upper arms last Saturday, but now have driver side wheel positive camber.
TRUCK TRACKS SUPER STRAIGHT, so, apparently, I do have toe in/out caught well from previous alignment.
Upper arms have 2 camber bolts. One per each arm leg, or whatever it is called. ends of Y with bushings.
I need to know, do I adjust BOTH camber bolts same amount, or just one bolt? May sound like a silly question, but won't it rotate arm and change toe, if I do not match both bolts?
Also, I have to do it with truck on the ground and wheels on. Any tips will help, single man job.
Old February 22nd, 2012, 8:56 PM
country_09's Avatar
Every time I've messed with it myself I do both at the same time
Old February 22nd, 2012, 9:35 PM
cleveland63b's Avatar
by eye it'll work better doing both but the only way to properly do it is with an alignment machine, any movement you do on either camber bolt will effect camber and caster on that wheel.
the way i do it is by jacking up the frame and reaching over the tire with i believe its a 21mm but i work in a shop with an alignment machine so the angles from raising the frame are compensated for
Old February 22nd, 2012, 10:29 PM
ukrkoz's Avatar
Oh, I can reach bolts fine around the tire. I was only making sure that both bolts must be moved same amount and same time. Do I really have to worry that much about caster?
Old February 23rd, 2012, 9:16 AM
as far as tire wear not really but it can change ride quality and if it gets way off possibly cause a drift
vwwebb
April 6th, 2011 1:37 PM
vwwebb
January 2nd, 2011 11:24 PM
clearcreek
January 2nd, 2011 9:34 AM
gmarcos74
November 30th, 2010 5:24 PM
caprice-classic 85
June 27th, 2010 8:29 PM
Quick Reply: Camber adjustment with wheels on
