Can I swap my 5.3 for a 6.6 Diesel?
RE: Can I swap my 5.3 for a 6.6 Diesel?
welll a Dmax engine is over 13 G Canadian anyhow, figuew a major front end redo, as the weight of a Dmax is crazy.....HOWEVER GM mad a 1/2 wiht a 6.5 a few years back, there are a few kicking around so it is possible but not for a reasonable amount of $$.......
http://www.trucktrend.com/features/t...nes/index.html
This article is about installing a 6.6 into a 89 K1500. They actually replaced the dash for electrical reasons. Hey don't forget to add to your bill an Allison trans. Being that the 4l60e can barely handle the 5.3l, I doubt it will handle the Duramax (assuming the housing matches up). I hope this article completely turns you off to this project. Sometimes I consider myself optimistic, but my gut is telling me this is going to be an expensive undertaking on your part. But if you do decide to take on this project can I have your engine and trans for my 65 chevy? j/k
ORIGINAL: silverado01ls
is there anyway i could make it work..i just dont want to spend the $25k+ to buy a new truck
Duramax in Silverado
Yes it's very possible. Guy here in Florida does it to Suburban, Tahoe and Silverado. You have to change transmission, front and rear axles and lift truck minimum of 3" for clearance. Fuel tank too and other electrical and computer changes also. Going to replace my 5,3 with a 2011 6.6 duramax.
+1 for just buying a used truck built for it.
things that don't match...the frame, trans, rad, axles, drivshaft, differentials fuel tank, multiple modules...do i need to continue
