Can't find my Power outlet, 110 AC (K14)
Hello:
Reviewing my "list of options" code sheet. I see:
K14-POWER OUTLET, 110 Volt AC on sheet but can not locate on truck.
Help..... where located?
Depends on if you have the a bench seat or buckets. If you have buckets, under the radio you should see 4 covered connections. Starting on the left, you should have the USBs, then the middle two are 12v cigarette lighter connections and furthest to the right is the 110 outlet. At least that's how mine is. If you have the bench seat, I believe they are in the armrest.
BIGBLACKTRUCK2014:
Thank you for your response......
I found the "110 AC Outlet".
My vehicle is may be referered to as BENCH seat with center storage arm rest that separates the front passagengers, but folds up to provide a place for third person (small) in front.
Any who.... the outlet is just below the INFOTAINMENT screen (at bottom of dash) and covered by a rectangle cover that looks like trim.
It's a two pronged (no ground hole) receptor. All good, works and allows me to use Phone charger.
Thank you Big Truck....
I was a big truck owner (2008 RAM3500 SRW Diesel) which I called "BIG Whitey". This Silverado 1500 I call "Little Whitey".
All good.
All good.
cplnorton
Silverado & Fullsize Pick-ups
February 11th, 2014 8:21 AM
