No brake lights
No brake lights
I have a 2000 chevy silverado 2500 and I have no brake lights but all the other lights work. I have replaced bulbs, tail light switch, tail light circuit board and checked all fuses and they still don't work what else can I do
if the chmbl works check the 10amp veh stop fuse in the underhood fuse box
if both the chmbl and back brake lamps are inop check the 20amp stop lps in the underhood fuse box.
if the 20 amp fuse is good check for battery voltage into the brake switch orange wire. if you have power in...depress the brake pedal and check for power out of the brake switch white wire.
Rednucleus (November 28th, 2021)
[QUOTE=tech2;473023]if the chmbl works check the 10amp veh stop fuse in the underhood fuse box
if the 20 amp fuse is good check for battery voltage into the brake switch orange wire. if you have power in...depress the brake pedal and check for power out of the brake switch white wire.[/QUOTE
I have checked all fuses they are good I took it to the shop and they said I have power going into the switch but not out so I changed the switch again and same thing no brake lights
I took it to midas and they said I have power going into the switch but none coming out and they told me to replace the switch and I did for the second time and lights still don't work.
Or to to a real mechanic shop, and Midas doesn't qualify as that.
Rednucleus (December 4th, 2021)
Sonya
June 14th, 2018 6:24 AM
LeeA
Silverado & Fullsize Pick-ups
April 13th, 2012 4:28 AM
