Notices
Sponsored by: DashLynx
Chevy 5.7l Vortec 1996 Timing very very retarded..WHY???
Old October 21st, 2010, 9:18 PM
mdm6713's Avatar
Default Chevy 5.7l Vortec 1996 Timing very very retarded..WHY???
What is involved in controling the advance / retard of the timing on the vortec 350? Im running between 15-35 degrees retard on my timing when it should be a few degrees advanced or at least near 0...I know theres no adjustment at the dist. itself by turning it...but what goes into the decision the truck is making to adjust timing that slow?
Ive replaced crank position sensor and knock sensor along with 4 02 sensors, one sensor was not giving a consistent reading back, I replaced it again and still have the same "lazy" reading. I realize I may have a wiring problem here(260K on a 96 model)
Any direction or help is appreciated
Michael
Old October 22nd, 2010, 2:23 PM
mdm6713's Avatar
any ideas guys? Im using a laptop based scan tool..thanks
Old October 22nd, 2010, 11:26 PM
tinbender59's Avatar
ok: if the Knock sensor "hears" a knock, it doesn't care what it is, it thinks it is "preignition" so it retards the timing and cuts fuel back some, trying to control the knock. this is the problem I had with a very agressive cam "to much noise" and this is why you NEVER see a solid cam in a EFI motor. nowto test this, as I said in the other post! unplug the knock sensor before you do any thing else. run it and look at your timing, if it comes back up? You may have noisy rods or mains, or even piston slap. with those kind of miles any thing is possable.
Old October 23rd, 2010, 7:48 AM
mdm6713's Avatar
Default replaced knock
Hey...i unplugged the knock before, seem to improve a bit so i put a new one on, it does run a little smoother, but the timing still off. Do you know what other sensors have a part in deciding timing?
thanks for your help again
Old October 25th, 2010, 10:46 AM
fuel pressure was the guilty culprit on my Tuned Port conversion, pressure was low so it was lean causing her to ping????.
Old December 30th, 2019, 4:41 PM
David Caffey's Avatar
Did you find the problem?
bryancoburn
February 15th, 2015 7:46 PM
xeqshnr
HHR
22
February 13th, 2015 9:18 AM
jakeywa
December 11th, 2010 7:18 PM
txguykev
November 17th, 2007 12:32 PM
Nimrauko
November 9th, 2007 11:45 AM
Quick Reply: Chevy 5.7l Vortec 1996 Timing very very retarded..WHY???
