dash board is flashing a weird code
Might have had a lift when new, then removed and sold. At least thats what I am thinking the ecm is looking for a lift, and now there isn't one. I don't know if you look for a fuse, and if there was one, AND removed (for that reason) I'd suggest not replace the fuse, if you have access to the original owner ask him if it had a lift. I am not that up on your problem.
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> pickawaykid,
It is coming up on the DIC, correct? Has the vehicle been modified? Would you please provide the last 8-digits of your VIN, so I can look into this further for you?
I look forward to your reply.
Louis
GM Customer Service
Louis
GM Customer Service
it flashes across the dash .no modifications . i thought a lift gate fuse was only on suv anyway the last digits of my vin 6g202398. truck does have an after market radio .
