takeoff?
takeoff?
okay guys i need ya help
how do i get more acceraltion??
i have exhaust.. tbs.. programer.. cold air intake.. and bout to put in elc fans on my 04 silverado 1500
so i have the top speed coverd. i can get bout 125 outta her. i jus need more acceleration.
Pretty sure, Powerchip has your vehcile model (but not 100%), I am using the powerchip tune on my Merc, and very pleased with Gain and reliability. visit their site to check cost and performance gain (hp/torque)
Why screw around? Obviously 300+ HP aint enough. Go to an airlines junkyard, and get a jet engine. Cost and fuel consumption isn't an issue, so google Artie Aarfons, and best of luck.
Just scrap that OEM POS, and weld that puppy in under the hood. Don't forget to make sure the exhaust doesn't overheat anything, and you're good to go.
well I'm not sure about jet engines... but typically this is a good rule of thumb
minimal cost/minimal gains = exhaust/filters/plugs/chip/etc
containable costs/decent gains = heads/blocks/bore/cams/pulleys/cranks/etc
higher cost/higher gains = supercharger/turbo
mega cost/mega gains = Rivereye's jets
If just looking for better off-the line perf, I would suggest looking at different gears and ratio's...
so u guys think cam and lifters will help? is there a certain brand u all woudl reconmend??
HAHAHAHA Jet enginge would be fun. but i doont think the neighbors will like me at 3 am goin to work.
what would shift kit do? would that helo me at all??
Check out Edelbrock and their specials; good cam companies are COMPcams and my personal favourite, Lunati. As MDTahoe said in another thread, its good to buy things in a set so you know they'll work together, and work well. You ought to be able to mix and match different spec cams in though.
They would warrant a decent horsepower gain, for sure.
What kind of gears do you have in your truck?
ok. ill look in to it. i jus put comp cams in my brothers 98 1500. that thing sounds nasty! exspecially wit the single in dual out glass pack. it took us full 24 hours to get the cam/lifters and high intake on. and runnin good.
umm i'm not totally sure what im rear gears are. they are not stock. but i didn put them in so i dont remember
