Notices
Driver Door lock doesnt work
Old March 21st, 2013, 3:56 PM
rdedwardz's Avatar
Default Driver Door lock doesnt work
I have an '09 sliverado LT extended cab. My driver door lock does not work with the button or key FOB. To lock/unlock the door you have to do it manually. When you mash the button you can hear the lock trying to move but it doesnt unlock. The passenger door works fine. I have seen some conversation on the forum with a similar complaint but no resolution. Anyone know what the problem is? Better yet what the fix is?
Old March 21st, 2013, 5:37 PM
xpeder's Avatar
replace the door lock actuator
Old March 22nd, 2013, 11:00 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> rdedwardz,
I am sorry you are experiencing this issue, as “xpeder” mentioned; this issue may be related to the door lock actuator. I recommend consulting with a certified technician for an official diagnosis and repair options.
Feel free to contact me privately if you have any additional questions.
Louis
GM Customer Service
Old March 23rd, 2013, 1:45 PM
door lock actuator x 2
Old March 23rd, 2013, 8:09 PM
rdedwardz's Avatar
Originally Posted by Chevrolet Customer Service
rdedwardz,
Louis
GM Customer Service
Louis,
Thank you for your message. I just replaced the actuator and it seems to have fixed the problem. My passenger door is starting to show problems indicating it too, will have to be replaced. The dealer i bought the part from commented about how many of this part he sells. It is dissapointing to know that GM is aware of such a common problem. Clearly the actuators from the factory are bad.
Old March 23rd, 2013, 8:44 PM
the way i look at it; if small stuff breaks i can deal with it. When the engine and trans go bad, its a lemon.
Old March 24th, 2013, 1:17 AM
cleveland63b's Avatar
every style/make/model has common faults, its the nature of the beast
goyakpacking
Express & G-Series Vans
May 9th, 2015 7:51 PM
cross
Equinox
November 19th, 2012 7:26 PM
mukherjee_mk
August 28th, 2012 11:18 PM
silveradolt1
January 13th, 2008 6:05 AM
98greenventure
April 1st, 2007 3:15 PM
Quick Reply: Driver Door lock doesnt work
