Notices
Repeated A/C Control Switch Failure
Old July 6th, 2007, 3:40 PM
dazadad's Avatar
Default Repeated A/C Control Switch Failure
I have a 1997 Silverado ext. cab V6 with power door locks and windows & a/c, 145k miles. I've had to replace the a/c control unit in the dash 6 times in the last three years. I have not been able to get anyone to help me determine what makes them go out. The people at the dealershipsay just change the unit out. There must be something in the system that is causing the PC boards to fail. Is there a common root cause for this? How do I troubleshoot this?[/align]
Old July 6th, 2007, 4:36 PM
ZX1100F1's Avatar
Default RE: Repeated A/C Control Switch Failure
Check the following circuits for a short to ground: [ol]Circuit 66 or Circuit 762 ( Gasoline Engines) Most common area is where the hvac compressor harness comes into the main harness by the left rear cylinder head.
Circuit 66, Circuit 603 and/or Circuit 762 ( Diesels Engines )
If a wiring checks out ok, replace the AC Low and/or High pressure switch for internally shorting out to ground. [/ol]
Old July 7th, 2007, 2:08 AM
dazadad's Avatar
I'm not sure that I can find these circuits. What does Circuit 66, Circuit 603 and/or Circuit 762 go to. Maybe I can trace them from the source. Is there a way to troubleshoot the high and low pressure switch?
ghows
January 11th, 2012 8:26 PM
Tango374
January 22nd, 2011 8:09 PM
PauloD
January 10th, 2011 7:35 AM
Heather_98burb
March 15th, 2008 2:39 PM
wdannhardt
December 6th, 2007 10:24 PM
Quick Reply: Repeated A/C Control Switch Failure
