Notices
Sponsored by: DashLynx
engine knock
Old September 25th, 2006, 10:17 PM
lroewer's Avatar
Default engine knock
I have a 2003 Silverado with the 6 cylinder. When driving at 20 to 40 mph, the engine idles at around 1000 to 1200 rpm. When I accelerate, there is a hesitation and engine knock. Any suggestions?
Old September 25th, 2006, 10:59 PM
ZX1100F1's Avatar
Default RE: engine knock
When you have a knock in these 4.3L engines that means that you have a lean fuel condition, usually caused by clogged fuel injectors or a restricted fuel filter.
Old October 23rd, 2006, 10:48 AM
SavageXman's Avatar
Run higher octane fuel and run a couple tanks through it with a good carb/injector cleaner. That should clear it up.
Old October 24th, 2006, 8:16 AM
uncle bill's Avatar
Usually, the computer will adjust the timing to eliminate the knock, so You may need a knock sensor.
stantonbox
December 5th, 2007 8:40 AM
matt21191
November 21st, 2007 4:17 PM
scoyoc5
October 2nd, 2007 6:42 PM
brudel1
November 20th, 2006 4:17 PM
Quick Reply: engine knock
