Notices
engine light flashing at 65 to 70 mph
Old November 16th, 2007, 5:21 AM
03chevyrustbucket's Avatar
Default engine light flashing at 65 to 70 mph
My 03 2500HD when going down the highway at 70mph my check engine light will start to flash. After the first time it flashesit only seems to flash when the engine is not under a load like when your going down a hill.I took it to the dealer and the code said it was cylinder #7 missfiring, they checked it and said there was nothing wrong withit and they sent me on my way less 70 bucks. Note: if I stay under 65 the light will never come on. I have changed the fuel filter and added injector cleaner to the gas with no luck.
Any help would nice.
Thanks
P.S. the truck is 6.0 engine with only 35k miles
Old November 16th, 2007, 11:06 AM
ZX1100F1's Avatar
Default RE: engine light flashing at 65 to 70 mph
If water is present in your fuel it is very common for the the #7 cylinder to misfire due to the design of the fuel rail water will pool in the #7 enjector area.
The fuel rail should be drained into a mason jar and the fuel inspected for water contamination, if water is found then you should have the fuel system proffesionally cleaned and purchase your fuel from a differetn station in the future.
You can also try adding several bottles of fuel system dryer to the tank, but if water has been present it may be that the #7 injector is damaged from rust.
Old November 16th, 2007, 11:36 AM
Why does it only do it atthe speeds I said
Old November 16th, 2007, 12:07 PM
ZX1100F1's Avatar
It is likely just slightly misfiring (always) but is probably so subtle that the ECM can't detect it until the RPM's are up while under a load when the misfire condition becomes more pronounced.
Old November 16th, 2007, 9:58 PM
santaman58's Avatar
Just info that might help. I was at dealer for an idle problem and the dealer pulled a report on 6.0 liter motors for that era and there was something there about possible factory defective #3 cylinder spark assemblies/coils. If I were you I would check the price of the #7 spark assembly and if it isnt too expensive, just change it anyway. Might even find one in the junk yard for reasonable amount. It might fix the prob if the fuel cleaning things didnt work.
Old November 17th, 2007, 3:31 AM
Thanks
Old March 4th, 2022, 9:46 AM
Wiscow's Avatar
Thanks
I know this is a very old post but I just got had the same problem, p0300 was my only code for months, eventually I got a p0404 egr performance code. Testing showed it was an actually bad egr valve. Changed it and now the problem is gone. Hope this helps someone out because there are tons of these exact posts with no answers. Chris
corbett
11
August 1st, 2017 6:51 AM
Apenas83
March 15th, 2011 6:44 PM
Sonicdog
Sonic (Aveo)
July 13th, 2010 7:48 AM
Chevyguy6
February 21st, 2010 12:28 PM
dustinh70
October 22nd, 2009 3:18 PM
Quick Reply: engine light flashing at 65 to 70 mph
