Notices
Sponsored by: DashLynx
engine oil/coolant leak issue on 04 silverado
Old September 27th, 2009, 1:38 PM
tat2dup81's Avatar
Default engine oil/coolant leak issue on 04 silverado
i was wondering if anyone has had issue with oil and coolant leaks in their trucks. but theres no leaks on ground. i have to had a quart oil after bout 3k miles after new oil change. needing info to fix
Old September 27th, 2009, 2:03 PM
therewolf's Avatar
The same thing happened to mine at 24K, under warranty, and 48K, after the warranty expired.
The most likely cause is a faulty seal at your water pump gasket surfaces. Fortunately, the Vortec V8 waterpumps arent that hard to get at, you do need a large strap wrench and a large wrench to get your fan clutch off. Most large parts stores carry all the tools and parts, including the gaskets.
At 48K, I replaced the fan clutch with a lighter unit.(The O.E.M. is a brick.) I replaced the water pump with a new one, added some Premium Hi Temp RTV sealer to the gaskets during re-assembly, and haven't had a problem since.
Old September 27th, 2009, 9:23 PM
JohnD17's Avatar
I just bought an 07 silverado i don't have any leaks but i saw a few 03-07 that were leaking from the cooler lines in the front.
Old September 27th, 2009, 10:12 PM
tat2dup81's Avatar
yeah i had my water pump replaced before and it was a small gasket that was bad. ive heard its the dexcool coolant that dries up the intake gasket that makes it leak internally
Old September 28th, 2009, 10:55 AM
therewolf's Avatar
Nothing that Fel-Pro gaskets and some good hi-temp RTV can't fix.
Old September 28th, 2009, 5:15 PM
tat2dup81's Avatar
what about the oil leakage? any ideas why the cause of having to add oil?
dlaroche
October 29th, 2014 7:17 PM
Eric Sherden
September 24th, 2013 1:21 PM
BobY
August 3rd, 2011 10:20 PM
95wt
May 30th, 2008 3:07 PM
larry_chip
April 24th, 2007 11:46 AM
Quick Reply: engine oil/coolant leak issue on 04 silverado
