Notices
Sponsored by: DashLynx
Error code question...
Old August 19th, 2012, 3:30 PM
rjdjbd's Avatar
Default Error code question...
Would like to post a question for a family member:
2000 GMC C1500 with a 4.8L engine - Error Code P1416
"All the testing and looking showed that the air pump solenoid relay was bad. I have power coming in to the relay but not out. I tested the pump and it works fine. So I got a new relay and plugged it in. Got power in and out now and pump on. A few minutes later pump turns off and only have power coming in again.
I would like to know if this pump is on all the time when car is running or does it cycle on and off? Or is there a common problem that makes the relay go bad."
Thanks in advance for any replies that could help sort this issue out.
Old August 19th, 2012, 7:42 PM
the system will not run all the time. Its pcm controlled and will run or turn off depending on a number of variables.
clear the code and drive on. The system will run the diagnostic for the p1416 and if it passes the code won't return.
dj59red
October 9th, 2007 4:39 PM
dj59red
October 9th, 2007 3:25 PM
tshunt01
February 19th, 2007 12:26 AM
Mother_Trucker
September 10th, 2006 12:01 AM
Quick Reply: Error code question...
