floating gas gauge - Chevrolet Forum - Chevy Enthusiasts Forums
Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Current Chevy Trucks, SUV's, Crossovers & Vans > Silverado & Fullsize Pick-ups
Log In
Search
Sponsored by: Bakliner
LinkBack Thread Tools Search this Thread
Old 10-16-2007, 01:45 AM
Junior Member
Default floating gas gauge
What would cause your gas gauge to float when your truck is in park and your idling. PLEASE HELP!!!!!!!!!!!!!!!!
Old 10-17-2007, 11:36 AM
Default RE: floating gas gauge
I have a issue that is similar. When my 2001 5.3 Z71 is totally full on gas it will drop totally empty and the gas light comes on. Then if I put into drive or hit a bump it comes back to full. It only happens when it is full. Strange,
Old 10-17-2007, 07:01 PM
replace the level sensor in the fuel tank
Old 10-19-2007, 06:32 PM
drop tank, remove and replace float, pump, and sensor.
__________________
1959 VW BAJA
1969 VW BEETLE
1993 CUMMINS
2005 CHEVY 3500
Old 10-19-2007, 06:49 PM
Might be easier and cheaper to get a whole sending unit. should be one piece. find part number and comparable models used. might get ebay or junk yard
__________________
Old 10-20-2007, 12:50 AM
Junior Member
hey fellas, i think i just need to get a new fuel pump and problem solved right.
[/align]
Old 10-20-2007, 12:55 AM
its in the tank
__________________
1959 VW BAJA
1969 VW BEETLE
1993 CUMMINS
2005 CHEVY 3500
Old 10-20-2007, 01:00 AM
Junior Member
dont quite follow you
[/align]
Old 10-20-2007, 01:03 AM
fuel pump is the "sender" unit. it is located inside the fuel tank . that is where the float that measures your fuel level is attached.
__________________
1959 VW BAJA
1969 VW BEETLE
1993 CUMMINS
2005 CHEVY 3500
Old 10-20-2007, 01:12 AM
Junior Member
i get that
[/align]
Similar Threads
Thread Thread Starter Forum Replies Last Post
rear semi-floating axle bearings VanGo Tahoe & Suburban DIY and Useful Threads 1 01-21-2011 09:40 AM
Installation Connection Problem: 0-Gauge to 8-Gauge, or Alternate? OnThePike Audio/Visual Electronics 1 08-04-2010 03:22 PM
2.2 1998 No Reading On Gas Gauge; Gas Tank HAS Gas ahearnm S-10 & Blazer 2 12-16-2007 04:22 PM
Fuel gauge and temp gauge not working wrxsubaruwrx Malibu 0 12-03-2006 01:33 PM
Tags
2000, chevorlet, chevrolet, chevy, floating, fuel, gas, gauge, gauges, guage, quit, registering, silverado, tank, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
