Fuel control system
Fuel control system
I have a 2009 silverado 4.3l with the engine light on. According to onstar there is a problem with the fuel control system. Any suggestions on a fix?
Are you out of warranty? If not take it in to the dealer. If you are out of warranty, go to Autozone and they will read the code for you for free and might be able to tell what the problem is.
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> srgariss,
I agree with "oldchevy", have the vehicle inspected for additional information. Is there still a warranty left on the vehicle?
Louis
GM Customer Service
Louis
GM Customer Service
It could be a fuel cap issue. If your gas tank cap is not screwed on all the way the engine light comes on. After you do screw it on it takes a lot of on off ignition cycles for it to go off or you can have a shop turn it off.
wmc3
Silverado & Fullsize Pick-ups
January 25th, 2012 11:40 PM
surfandride
January 16th, 2011 10:05 PM
