Notices
Fuel injection to Carb' Swap-1995 2wdRegCab-ECU HELP
Old June 5th, 2012, 9:40 AM
agentruley's Avatar
Default Fuel injection to Carb' Swap-1995 2wdRegCab-ECU HELP
So I have a 1995 c-body 2wd Regular Cab truck and currently it is a 5 speed with a 4.3L TBi v6, which is utter junk. I am going to pick up a 350 soon that is a traditional 350 that is carb'd. What signals do i need to feed the ECU to make sure it still deploys the airbag? I know speed from the transmission, Voltage from the alt' and some how RPM's. I am thinking of getting a MSD ignition setup and i bet you could use some kind of signal or data line from it to feed into the ECU.
I might also pick up a different transmission which im sure all modern ones (t56) have that speed sensor or signal that goes to the ECU.
I am pretty smart about traditional things but the Newer ECu's im having trouble learning about.
Old June 6th, 2012, 7:10 PM
agentruley's Avatar
Awww comeon. Does nobody know about this? I just need to airbags to deploy so that the car can still be safe. Screw everything else. I mean the check engine light can come on and all that stuff and it doesnt matter.
Old June 6th, 2012, 9:06 PM
Doug Roberts's Avatar
That's a lot of info bro lol ill do my best and see if alldata got it I got full ver give me time
Old June 7th, 2012, 9:55 AM
agentruley's Avatar
Ok. Thank you.
I just want to be able to turn the key on and everything the ECU needs to make sure the airbag deploys is available to it. I will have like almost a whole 'nother wiring harness for the engine and i will be able to cut it off and start it with my own switches which i am installing right now.
Old June 7th, 2012, 6:48 PM
agentruley's Avatar
Awww come on. Doesnt anybody know anything about this?
Old June 8th, 2012, 5:33 AM
agentruley's Avatar
bumpity bump
Old June 10th, 2012, 9:57 AM
agentruley's Avatar
bump Does ANYBODY know ANYTHING about ECU's?
Old June 10th, 2012, 10:07 AM
I looked foe like he or so I didn't see it
best thing call a radio shop and see if they know
Old June 10th, 2012, 10:58 AM
agentruley's Avatar
radio shop?
Cant some one just tell me the things the ECU needs?
Old June 10th, 2012, 1:01 PM
Yeah cuz most do alarms and know the electronics inside and out you may have to shop around but Ecu is kinda a black box to most people
Quick Reply: Fuel injection to Carb' Swap-1995 2wdRegCab-ECU HELP
