Notices
Fuel pressure on 97
Old August 3rd, 2012, 12:07 PM
Kahuna6719's Avatar
Default Fuel pressure on 97
Hey all hope everyone is having a good friday. Quick question when I turn key to on postion fuel pressure goes up to 54 lbs. then quickly drops to 25lbs. Would this be a pump or regulator problem. I was told if it was regulator, pressure would drop to 0 with in a minute. Mine only drops to 25 lbs.
Old August 3rd, 2012, 1:19 PM
kevinkpk's Avatar
pull the vacuum hose off the regulator, gas comes out diaphram has a hole. What is the idle rpm?
Old August 3rd, 2012, 7:34 PM
shamrock246's Avatar
On the 97 there is no vacuum hose the regulator is inside the intake manifold it could be a regulator or a fuel pump if your going to do a regulator i would just spend the extra money on the spyder upgrade amazon has them if you do the pump use a AC/DELCO one i hear the other ones dont last thats what i did and do a fuel filter at the same time as the pump
Old August 4th, 2012, 12:59 PM
cleveland63b's Avatar
whats the pressure while running? id be leaning towards the pump myself
bholaday
April 2nd, 2021 5:51 PM
solerano
September 1st, 2013 5:26 PM
Aaron@Airlift
August 2nd, 2012 9:33 AM
gdavies07
November 7th, 2011 11:47 PM
williamvaldivia
March 19th, 2009 11:03 PM
Quick Reply: Fuel pressure on 97
