Fuel pump not working in the cold?
Hello,
I'm new to this forum and hoping I can get some help. I bought a 94 GMC and when I bought it the battery was dead and truck wouldnt start so I got a good deal on it. I got it home put it in my garage replaced battery started right up. Drove it a few miles started cutting out turned around parked it outside. And wouldn't start back up. So pushed it in my garage. After it sat in my heated garage all night it started back up. So I parked it outside in negative 40 degrees(alaska). Went to go to work the next day. Wouldnt start again. The engines not getting fuel. So after looking everything over I spliced into the gray wire on the fuel pump and touched it to my battery and still no fuel. I am guessing this means a new fuel pump... but why am I only having this problem in the cold? Is it really the fuel pump or is it something else?
I put the truck inside today and after a few hours it started up. Put the truck back out side and it idled for a few minutes I pressed the gas a little and it cut out and died but fired right back up I am so confused idk where to go from here or where to start. I just cant figure out why after it gets cold the fuel pump won't kick on. Do you guys have qny idea of whats going on?
Johnrockys
October 13th, 2013 3:02 PM
hunter10220
Silverado & Fullsize Pick-ups
May 18th, 2011 8:37 PM
ross_boss08
August 4th, 2008 2:41 PM
