Notices
hearing a "water" noise...
Old May 7th, 2009, 2:20 PM
  #11
98white5.0's Avatar
Exactly, but if money is a concern, and the pain is a concern, he could do the bypass to delay the inevitable. Since it's May, he will have a few months to forget about it. When it gets cold, he will remember real quick, though. BRRRRR!
Old May 10th, 2009, 12:04 PM
  #12
ricochet2410's Avatar
I have heard the same thing in my 2000 Z71!!! It had been doing it for a few years now. The weird thing is my heat gets hot and a/c still works but it will only blow out on the dash. I found a friend with a switch I replaced and it worked for a week or so now its back to blowing out on the dash and no where else. Got any ideas?
Old May 10th, 2009, 12:13 PM
  #13
EvansBlue's Avatar
A sloshing could indicate a full evaporator drain pan caused by a clogged drain as well. If you have run the A/C much, the condensation will build up in the pan if the drain is clogged. Just a thought..
Old May 11th, 2009, 7:13 AM
  #14
samger2's Avatar
Well I've still not had a chance to check it out...things have been busy, but thanks for all the stuff to check and hopefully I'll get cracking this weekend.
Old May 11th, 2009, 7:26 PM
  #15
samger2's Avatar
By the way...I just popped the hood to take a peek around and the coolant reservior is completely dry...
Old May 11th, 2009, 9:12 PM
  #16
suzuki-guy's Avatar
i hear that same noise.................................OHhhhh its acase of beer on my floor LOL
Showgoat (November 30th, 2023)
Old May 12th, 2009, 8:06 AM
  #17
samger2's Avatar
hahahaha...maybe if I put a case of beer on my floor I'll forget about the noise...
Old May 12th, 2009, 5:08 PM
  #18
suzuki-guy's Avatar
youll only forget about the noise if you drink the case of beer
Old May 12th, 2009, 6:09 PM
  #19
therewolf's Avatar
Yeah, the Vortec engines have a crappy seal at the waterpump/block. The sloshing water noise might be an effect caused by a loss of coolant. It's hard to spot, but surprisingly easy to fix with some good quality high temp RTV sealer and some good name-brand (like Fel-Pro) gaskets.
Takes a large strap wrench, and a flat wrench to fit your fan clutch, but it's very accessible, compared to older engine models.
Old May 13th, 2009, 9:13 PM
  #20
samger2's Avatar
So today I did notice there was water on the passenger floor...not alot, but some nonetheless...but it was a rainy day, so I'm not sure if the water has to do with a leak in cowl area or something else...
Quick Reply: hearing a "water" noise...
