Heater blower only works on High? 2003 HD - Chevrolet Forum - Chevy Enthusiasts Forums
Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Current Chevy Trucks, SUV's, Crossovers & Vans > Silverado & Fullsize Pick-ups
Log In
Search
Sponsored by: Bakliner
LinkBack Thread Tools Search this Thread
Old 11-11-2006, 08:26 PM
Default Heater blower only works on High? 2003 HD
My borther-in-law has a 2003 3/4 ton Silverado and he's telling me the heater blower motor only works on high, no other speeds. Anyone have any ideas?
Old 11-11-2006, 11:22 PM
Default RE: Heater blower only works on High? 2003 HD
I had same thing on a '95. I had to replace the entire heater/ac control unit since you can't replace just the fan switch individually. Not cheap.
ChevyBlues
Old 11-12-2006, 04:13 AM
save your $ 02Lightning, and check the relay & hi-low speed controller on the heater box. when it only blows on 'high' it usually means the speed controller is gone. this is the one that goes into the heater box assm. @ the top, and has 3 different sized coils on the back side of it. i'm not saying the heater/AC control is not the problem, but this is going to be alot cheaper to replace. i used to have the values for the resistance of each coil to check if it was bad, but i can't seem to find it. before u replace the speed controller though, try tapping on the relay, which is usually mounted 2 the side/front of the heater box. if this doesn't change the speeds @ which it will operate, then go onto the speed controller. see how this works out 4 u.[sm=signs003.gif]
__________________
no replacement for displacement (8p
Old 11-23-2006, 02:21 PM
check your blower motor resistor it happend in my 1995 chevy 2500 what happens is the fuse blows but there is a bypass on the resistor to allow for you to still have heat. It will be located near your blower motor look in a chilton manual or just look online to see what it looks like though it probably faces down inside a compartment so I cant really explain what to look for. Its a $10 fix not bad at all
Similar Threads
Thread Thread Starter Forum Replies Last Post
2003 Impala A/C blower switch only works on position 5 tinytec Impala 11 01-06-2015 06:34 PM
Blower only works on high kevin3251 General Tech 1 07-08-2010 09:30 PM
2003 Silverado with Heater Problems.. only works after I go 60mph sbasmiles Silverado & Fullsize Pick-ups 2 01-07-2009 03:03 AM
Heater blower moter only works on high? dylskee Silverado & Fullsize Pick-ups 6 05-12-2008 01:39 AM
Heater works, then doesn't, then works again ['04] brenande Silverado & Fullsize Pick-ups 5 01-27-2008 01:40 AM
Tags
03, 2003, blower, blows, change, chevy, control, fan, heater, hhr, high, motor, runs, silverado, trailblazer, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
